I hate flash, i would much rather turn on a light in the room than use it when taking pictures
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/
I use flash only if it's really dark. I'd rather use HDR or low light mode
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-922543
There are creative ways to use flash. I don't like using it because I feel like it drains my battery fast :P
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-922580
While I rarely use flash, there are times when I need it for fill. We used properly, flash can look use like natural light. The key is to use it off camera or at least diffuse it somehow.
CPU AMD Ryzen 2700 X / Motherboard  / RAM 4 x 4GB  / GPU Zotac 1080Ti Amp Edition / Case Fractal Design Meshify C / Storage Samsung 850 PRO / 1TB WD Black & 2TB WD Green / PSU / Cooling Noctua / Keyboard Ducky Shine 2 / Mouse Logitech G700 / Sound O2 Amp/DAC & Audioengine A5+ speakers
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-922816
its on auto for me!
work it ᕙ༼ຈل͜ຈ༽ᕗ harder, make it (ง •̀_•́)ง better, do it ᕦ༼ຈل͜ຈ༽ᕤ faster, raise ur ヽ༼ຈل͜ຈ༽ノ donger
ᕙ༼ຈل͜ຈ༽ᕗ HARDER, BETTER, FASTER, DONGER! ᕙ༼ຈل͜ຈ༽ᕗ
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-922835
I like to use my 1.8 35mm lens and very long exposures like 1/20. with my cam i still get sharp images that way. With the built in flash you can see everything you don't want to see (in faces the imperfections and on plastic or metal you see dust and little scratches)
        wow... pretty empty here...
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-923471
why use a flash when you can change the iso. flash is only used to bring the ambient light in the room up enough so you can low your iso and capture the same color your eyes see in the room.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-923506
Because high ISO leads to grain..
Built in flash is ok if you put a piece of paper at a 45 degree angle in front of it.
CPU: i7 4770k | GPU: Sapphire 290 Tri-X OC | RAM: Corsair Vengeance LP 2x8GB | MTB: GA-Z87X-UD5HCOOLER: Noctua NH-D14 | PSU: Corsair 760i | CASE: Corsair 550D | DISPLAY:  BenQ XL2420TE
Firestrike scores - Graphics: 10781 Physics: 9448 Combined: 4289
"Nvidia, Fuck you" - Linus Torvald
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-923653
or spend the big bucks on a nice flash and diffuser.  :D
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-923795
I do not use on camera flash. I have used off camera flash to do some cool things though.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-923878
Yes, pretty much every shot I take has a flash involved, its never on the camera though. Even large landscapes its fun to throw a flash(es) in to highlight certain objects or small buildings.
Generally, flash tends to ruin pictures. Natural/reflected light usually works best.
I dunno I actually prefer the look of flash, if used correctly, or a combination of both.
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-933213
By flash I presume you mean on camera.
If so, no way. Never used it.
I use a 430EX II, i always try to bounce, diffuse or use it in an interesting way.
I really don't like un-natural light and always try to avoid it to get a natural soft light with nice tones and good placement.
https://linustechtips.com/topic/67409-do-you-use-flash-cameras/#findComment-966697
