How do increase my LAN speed?
Solved by Donut417,
10 minutes ago, PutUsernameHere said:My problem is that when I am streaming my Xbox to my PC, it is struggling with transmitting the whole image in full resolution. When I go to the information about my wifi from my PC, the speed hovers at about 150Mbps. I know that my router is capable of 3.2 Gbps so that probably isn't the bottleneck. What is causing the difference in speed and is there anything I can do to increase the wireless speed of my network?
Doesnt matter how fast your router is. If the Wifi card in your computer is only a 150Mbps N card then thats the speed. Your network works as fast as the slowest device. Be it your router or your wireless card.
