Fan controller with 0 RPM mode?
Solved by done12many2,
Just now, RadiatingLight said:Alright. now that I know that they exist, where do I get one. also, what would happen if I connected my fan to the CPU header slot on my motherboard. is there like a fan header splitter?
Amazon, Newegg, Micro Center, or just about any retailer that sells computer parts. Yes, there are 3 pin and 4 pin splitters available in tons of different configurations. Hooking these up to your CPU fan header is completely fine. Just make sure you do not exceed the total rated power capacity of that header.
