Hey guys, recently I moved my entire system to a new case (arc midi r2) and in the process something must have gotten screwed up because I've never seen anything like this in my entire life...
Currently I have an fx-8350, corsair vengeance ram, gtx 650ti, 500w thermaltake tr2 (terrible and soon to be replaced) as well as an m5a97R2.0 ASUS mobo, Windows 7 64-bit installed on 128gb Samsung SSD
I booted my system up after moving everything over and when I did it booted just fine, started browsing the web, everything was just fine. Then all the sudden programs began to crash...One after the other, Razer Synapse, Spotify, Logitech Gaming Framework, even Windows explorer crashed...
My first thought was perhaps the memory got bumped, so i reseated the ram as well as the graphics card, it still had these problems. I ran the Windows Memory Diagnostics, found no problems with the RAM...
I then launched the windows repair afterwards, and my goodness it looked like I was running Windows '95 as it said "Installed Windows 7 Service Pack 1" ... I quickly rebooted and found myself back on my computer as if everything was okay. Then once again programs began to crash one after the other, and as I'm writing this I fear Chrome might crash on me again
Someone please help me get to the bottom of this as soon as possible,
Thanks
Arc Midi R2 | ASUS M5A97r2.0 | AMD FX-8350 | EVGA GTX 780 FTW Edition | Corsair Vengeance 8gb | Corsair RM650w Gold | H100i Cooler | 128gb Samsung SSD | 2tb Seagate Barracuda | 3tb Seagate External
Peripherals: 23" Samsung SyncMaster2333 | Acer 27" 1080p | Corsair Vengenance K70 Cherry MX Blue | Logitech G602 | Razer Megalodon Headset | Vespula Gaming Pad
https://linustechtips.com/topic/66979-help-constant-crashing/
Just run windows repair. It might look legacy but actually works fine. Also recheck every cable inside case. Something like case switching should not effect on anything. You can clear CMOS if feeling like it but since nothing else except case has been changed I don't see point. Its propably just loose cable or one ramstck might be loose.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/66979-help-constant-crashing/#findComment-916654
Run the computer without the gpu and see if there is any problems still. Also do the same if you have two sticks or more ram try them individually and see if this fixes anything. Seems like you have an hardware failure, also check the cpu thermal compound if there is enough and if its seated properly
CPU:Intel i7 2700k OC @4.9Ghz cooled by custom water loop with xpsc dual240 rads, xpsc block and 750 pump/res|Ram:G-Skill RipJaw X 32GB 1866Mhz|Case: Corsair 750D|Motherboard:Asus Sabertooth Z77| Hard drive: 240GB Kingston SSD, Seagate 2TB, 1TB Hitachi |GPU: EVGA GTX 770 SC cooled by custom water loop with xpsc gtx 770 block|PSU: Corsair HX750|Monitor: LG 27 inch IPS LED Cinema| Sound Card: Creative Fatal1ty X-FI professional| Build log:
https://linustechtips.com/main/topic/64792-just-finished-off-first-watercooled-rig/
https://linustechtips.com/topic/66979-help-constant-crashing/#findComment-917065
This is so depressing...
https://linustechtips.com/topic/66979-help-constant-crashing/#findComment-917329
New PSU + Fresh OS install = fixed
ps,
thermaltake 500w tr2 is a piece are garbage
https://linustechtips.com/topic/66979-help-constant-crashing/#findComment-918374
