i was making a build on pcpartpicker but this poped up but i dont understand it and i was wondering if anyone wants to help me
Compatibility Notes
  • The motherboard M.2 slot #0 shares bandwidth with SATA 6.0 Gb/s ports. When the M.2 slot is populated, two SATA 6Gb/s ports are disabled.
https://linustechtips.com/topic/669683-i-dont-understand-pls-help/
Compatibility Notes
If you use the M.2 slot, it'll disable some of the Sata ports.
Compatibility Notes
If you use the M.2 slot, you will have two of your SATA ports disabled. What board is it?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
1 hour ago, Verydoge69 said:
@ARikozuM it is MSI Z170A KRAIT GAMING 3X ATX LGA1151 Motherboard.
do you know a mother Board that i shoud use?
well are you going to use a M.2 slot? if not your fine, and even if you do losing 2 sata ports is not a big deal
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
5: RAM upgrade, i want 16gb of black ram
order 1-5 is what I want the most,
color is of importance (most to least)
It looks like if you use the M.2 is used, the two SATA on the lower-right will be disabled. This is normal for most motherboards. If the Krait matches the look you're going for, it's a good match.
What kind of motherboard are YOU looking for?
What is the rest of your system configuration (e.g. number of HDD, SDD, graphics cards, etc).
The motherboard has six (6) SATA III ports.
If you will only be using say...3 HDD's (1x M.2, 2x SATA HDD's), then the "compatibility notes" won't be a problem.
You are only using 2 of the 4 SATA III ports (2 gets disabled when you used the M.2, so only 4 is left).
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
How many SATA ports do you want to use? if it's 4 or under then you're all set, you'll just have to use SATA 1,2,3,4
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
21 minutes ago, Verydoge69 said:
You're fine then.
If even you use the 950 PRO in the M.2 slot, you still have four (4) SATA III ports -- and you only have ONE (1) SATA HDD, which is your WD Caviar Black.
You have nothing to worry about.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
1 minute ago, -rascal- said:
You're fine then.
In this case his SATA ports should be fine while his eSATA is disabled.
