loking for a monitor
Kantor
resently one of my monitors has started to fail. io like to use two monitors due to space restraints when one of them started to fail i bought a DELL U2417H 24IN INIFINTY-EDGE MONITOR to replace it but due to my bad luck the other monitor has started to fail. Im asking for any advise on what i should get to replace it im thinking of getting another Dell inifinty edge or something simmer?.
build: Frankenstein http://au.pcpartpicker.com/list/QLBRVY
i know it's nuts but the drives i bought over time as i need more storage.
how exactly is it failing?
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
it will turn on for a couple of minutes and then just turn off other wise the display is fine and it doesn't matter what input i use it will last maybe five minutes then nope i tried on my old pc and same behavior i tried the port on a different monitor and it worked fine.
