6700K Temps
6 minutes ago, CromaT said:So should I be concerned? I have double checked to see if my cooler is making proper contact on the CPU and it definitely is. I did use Antec Nano Diamond thermal paste which was old (4-5 years) and was not to easy to get out of the tube. I had a 2500K at 4.5ghz on the same cooler and if i remember correctly under load would only get to about 64c. With the new 6700K at stock settings with prime95 (lastest version) the temps get into the 80c+ mark. When playing games however (ARK, GTAV etc) the highest it has gone is 66c.
What did I say again? Reason why older versions are cooler is the lack of FMA3, which the 2500k also lacks. So there's really no difference running 26.6 or 28.9 on a 2500k as far as heat goes, whereas with a 6700k (that has FMA3 support) it's night and day.
FYI, 80+C on P95 and mid 60 in game is perfectly normal. Mine right now is on the high 70s, licking the low 80s every second or so. Don't sweat about it.
