6500 build vs 4690 build
Solved by 79wjd,
16 minutes ago, trentklein said:Thanks! I will go with the 6500. Just need to find a decent cheap mobo with enough fan headers.
Literally any LGA1151 board is fine. And you can get a $5 fan splitter, so I wouldn't worry about fan headers.
8 minutes ago, aisle9 said:There's an MSI B150 PC Mate mobo on Amazon for $80. My wife just built an i7-6700 rig with it. Plenty of fan headers, very easy to work with.
There are also plenty of good H110 boards for like $50 that don't sacrifice anything really important considering he's trying to save money.
