Cheap WiFi solution
007agentHP
So my WiFi adapter just died on me.
I need something that can support a 120 mb down 95 up connection, while receiving signals through quite a few walls.
I prefer Newegg
What's the cheapest thing that can accomplish this task while being good quality (either pcie or external)
Thank you for your help
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
a cable :P anyway stay away from the lower end TP-link shit. i have had such a bad time with them with constant drop outs, bad speeds, packadge loss ect... they are basically shit unless you go high end and even then im sure there are better options
Builds:
Ive been using this: http://www.newegg.com/Product/Product.aspx?Item=9SIA4HM32K0022&cm_re=netgear_wifi_adaptor-_-9SIA4HM32K0022-_-Product
So far its been great and comes with a stand, supports dualband and errythang.
P.S. wifi cant be pulled through walls to recieve a signal it all depends on your router and how well it transmits also how much obstical interfear with that broadcast.
