There's a silverstone one which isn't very good...
I just painted my H100i white and it looks fine.
https://linustechtips.com/topic/666681-white-liquid-cooler/#findComment-8605358
You painted the rad as well? Overall bad idea if you did, since it might hinder cooling performance.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/666681-white-liquid-cooler/#findComment-8605452
No, just the tubing and block.
If you want to paint the rad you can paint the outside of it.
As long as you don't paint the fins there is no performance impact.
https://linustechtips.com/topic/666681-white-liquid-cooler/#findComment-8605495
1 hour ago, Nipplemilk909 said:
any white liquid coolers out ther ? im debating of liquid or cryorig r1 universal
Deepcool has the Captain series with white pums and fan blades, black radiator and fan frames, and the Captain EX series with white pumps, radiatos, and fan frames, and black fan blades.
https://linustechtips.com/topic/666681-white-liquid-cooler/#findComment-8605755
