I've put this together for my friend -  http://pcpartpicker.com/list/WNZQd6  . He wants to be able to play LoL and CSGO without lagging in team fights or on bigger cs maps, with enough FPS for a 120 or 144 hz monitor to be effective. The monitor will be bought separately and we already have a hard drive and OS along with a Gigabyte 750 TI. We're trying to keep it cheap but he's willing to spend money on a good bang for the buck build.Thanks dudes!
Intel Core i7 4770k | MSI Z87 | 8GB DDR3 1600Mhz  Kingston HyperX | GeForce GTX 780 | Fractal Design Define R4 | 1TB WD Blue | CX600 | Corsair H100i
https://linustechtips.com/topic/666190-build-for-a-friend/
Why not this instead?
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($174.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard  ($56.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($62.99 @ Newegg)
Case: Zalman Z3 Plus White ATX Mid Tower Case  ($34.99 @ Newegg)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($54.99 @ Newegg)
Optical Drive: LG GH24NSC0 DVD/CD Writer  ($14.89 @ OutletPC)
Total: $424.71
Generated by PCPartPicker 2016-09-24 17:06 EDT-0400
And btw... Don't hope for "144hz" with a 750Ti. Maybe in League of Legends, but that's about it. And Minesweeper.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/666190-build-for-a-friend/#findComment-8600264
13 minutes ago, EnemySp0tt3d said:
yeah idk  about a 750 ti and 144hz
I'm pretty sure a i5 and 750 Ti can run LOL and CS:GO at 144Hz/FPS
Total: $424.71
That's better
https://linustechtips.com/topic/666190-build-for-a-friend/#findComment-8600286
I don't see a discrete GPU?
Read his post, he's got a 750Ti already and wants to keep it.
https://linustechtips.com/topic/666190-build-for-a-friend/#findComment-8600291
