its okay, dont get a z170 board unless you are overclocking though
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/665210-first-build/#findComment-8590883
1 hour ago, nitrodeuce13 said:
So I am going to build a computer for the first time. I pretty much know how to do it. I'm just looking for some tips
Also here is my list: http://pcpartpicker.com/list/6D3t3F
Let me know if there are going to be any bottlenecks in the build.
Go for a quad core at least the 6500. Get a rx 480 and a better power supply imo
https://linustechtips.com/topic/665210-first-build/#findComment-8591175
i5-6500 / RX 480 4GB
PCPartPicker part list
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($198.88 @ OutletPC)
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard  ($77.98 @ Newegg)
Memory: Avexir Core Series 8GB (2 x 4GB) DDR4-2400 Memory  ($39.99 @ Newegg)
Storage: Avexir E100 240GB 2.5" Solid State Drive  ($60.98 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($45.71 @ OutletPC)
Video Card: Sapphire Radeon RX 480 4GB NITRO+ 4G Video Card  ($229.99 @ SuperBiiz)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.69 @ SuperBiiz)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Newegg)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($30.00 @ Kinguin.net
Total: $810.21
Buy cheap OS on Kinguin / https://youtu.be/yXTqz3Fd28M
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/665210-first-build/#findComment-8591297
You could try something like this http://pcpartpicker.com/list/ZT3t3F
https://linustechtips.com/topic/665210-first-build/#findComment-8591540
