so for the past year i have been using a ddc 3.2 pump.
i believe this is the root of my problems with temperatures.
the lowest temp i run in games on my cpu and my gpu's is 60 degrees not overclocked fans cranked to max and pump at full tilt.
i was thinking about maybe trying a new pump since i have replaced every other part.
i would like a recommendation that can handle this system 240 slim rad 360 thick rad sli gtx 970's and an i7 4770k (delided)
please and thank you :)
CPU: I7 8700k @ 5ghz | Motherboard: Asus Z370-Prime | RAM: White Crucial balistix DDR4 2133mhz | GPU: GTX 1080TI | Storage: ssd HyperX 240gig, 2x2tb seagate Firecuda 1tb, BPX 480 gig nvme, 1tb sandisk ssd  | Cooling: Custom loop | PSU: Evga supernova 850w G2 | Case: Phanteks enthoo evolv atx black White modded | system theme: White/RGB/Weiss
https://linustechtips.com/topic/664772-pump-recomendations/
You might want to check that your waterblocks are not clogged if your temps are that high.
A DDC is definitely enough for that loop.
You flushed your radiators before using them, I hope?
But if you want to upgrade your pump anyway (because the DDCs are hot and loud) buy a D5, any D5, and it will be awesome.
https://linustechtips.com/topic/664772-pump-recomendations/#findComment-8585871
For a system with that many components, a ddc pump would be way too weak and probably strained it a lot. A D5 pump would be the recommended and would easily pump the system.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/664772-pump-recomendations/#findComment-8585874
The DDC unit is a pretty powerful unit with good pressure espically since that is the 18W one, do you have a photo of the loop it may give us a better idea as to what the problem may be.
https://linustechtips.com/topic/664772-pump-recomendations/#findComment-8585876
i did flush my rad's and my blocks are very very clean.
sounds good. but 2 other people are saying that its fine.
http://imgur.com/a/9NptQ
https://linustechtips.com/topic/664772-pump-recomendations/#findComment-8585898
A DDC has more head pressure than a D5.
There is no reason why it should not be enough for all his components.
https://linustechtips.com/topic/664772-pump-recomendations/#findComment-8585904
Sorry about that, I thought that the d5 was an all around better pump. I probably should know it before I type it.
https://linustechtips.com/topic/664772-pump-recomendations/#findComment-8585911
Hmm that looks good to me nothing screams out something is wrong, btw what blocks/cards are those, is it a custom modification?
As Enderman mentioned the blocks potentially may be clogged if the loop has been up for a long time.
https://linustechtips.com/topic/664772-pump-recomendations/#findComment-8586077
this issue has existed since i first made the loop. i have just lived with it. i dont think its clogged blocks.
https://linustechtips.com/topic/664772-pump-recomendations/#findComment-8586094
