hi there
i want to buy the corsair spec alpha case, before i do that i wanna know if i can replace the side panel with a complete flat glass one, like the nzxt  s340or the nox hummer mc/zs..
  http://www.pcgameware.co.uk/images/NZXT-S340.jpg
i like the corsair spec alpha, exept the beveled side panel !!!!! it also has small glass window it only show small components inside, outch big faaaaaaail.
http://www.techspot.com/articles-info/1169/images/Image_02S.jpg
so can i do that ? i'm new to building gaming pcs, thanks in advance
https://linustechtips.com/topic/664703-the-corsair-spec-alpha-problem/
so sad to hear that, i guess i'm gonna start looking for another case,
yes it does show gpu, and cpu cooler, its all what it does actually, unlike the other cases i see around with big windows which makes it extremely good looking with the light poping up from right and top fans.
There are no premade flat side panel windows.
You would need to mod your own.
You can still see plenty through the spec's window, look at my build log and PSU basement mod in my signature.
i like linux
