I did a thing... And well!
Charcoal_
Who the fuck uses the SG553
PSU Tier List | CoC
Gaming Build | FreeNAS Server
Me...
My Build: Night Fury | i5-6600k @ 4.5Ghz | R9 390 | 850 EVO 250GB | 1TB Seagate | H230 Black
Night Theme User
         Hello Fellow Night Theme User | Why Aren't You Using Night Theme?
Just now, Charcoal_ said:
Me...
Image result for you're bad and you should feel bad
PSU Tier List | CoC
You should feel bad
I feel the same as I do before, you ruined my moment... I'm terrible at his game anyway...
Night Theme User
Me, its fantastic
1 minute ago, ShadowCaptain said:
Me, its fantastic
AK > SG553 :S
PSU Tier List | CoC
Me, its fantastic
Thank you!
Night Theme User
AK > SG553 :S
M4a1-s > AK
AK > SG553 :S
Depends on the needs
the SG553 is more accurate scoped and is so easy to headshot people compared to the AK
AK is better at spraying with its easier pattern
If you have tons of money, it makes sense to spend more on the SG553, also has a better ROF in close quarters  - but its awkward to use at medium distance as unscoped its shit and scoped you cant see
if you need scope then get AWP
Depending on the map and whats happening in the game, that might not always be the best option
The SG give you the ability to get scoped long range shots, and also a decent SMG style weapon for storming through places instead of relying on a pistol
Yeah....no, an AK is better if you're not crap at aiming. There's a reason why the SG553 isn't really used competitively (and its not just cost).
PSU Tier List | CoC
Yeah....no, an AK is better if you're not crap at aiming. There's a reason why the SG553 isn't used competitively.
Because its less reliably good, the spray pattern is awful for full auto so really only works in like SMG range
Really its only best when used scoped, which most pros dont want to do unless its an AWP
Never said I played competitively but the 553 and AUG HAVE occasionally been used successfully in pro matches
ez monayyyyy $$$$
I played the game once and because the only recent fps games had aiming down sights, I used it xD I don't play CS:GO seriously though.
Real men use SSG08 :P
2 hours ago, dexxterlab97 said:
M4a1-s > AK
M4A4 > M4A1-S
        Sample Text ( ͡° ͜ʖ ͡°)
Just now, sgtcool said:
M4A4 > M4A1-S
No. Better recoil, more damage. M4A1-S is the best
Also who the f*** plays that map
Locked. This really belongs in a status update.
Guest
