Need some help with batch
Joveice
Hi, I need some help with a batch file
The code I use is this:
    @echo off
   setLocal Enabledelayedexpansion
for %%d in (c d e f g h i j k l m n o p q r s t u v w x y z) do (
  if exist %%d:\ (
     ECHO Device Found : %%d
I need it to only post out CD drives or DVD.
So etc, D is a CD drive, it will then only say D
Back-end developer, electronics "hacker"
so you want the script to check if the drive is a Dvd drive and then write the letter if found?
I'm not sure you can do this, but you could maybe try writing to each drive, an empty drive would fail where as a disk drive would not.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Yea, And I could try that
