Asrock Phantom Gaming OC 7800 XT and fitting in case
Solved by Salted Spinach,
Should fit going by that picture above if its actually a 302mm card (it looks like it can take something that is 28mm longer)
Manufacturers may have consistent measurement methodology within their own business, some based on the assumption that the front fans are mounted inside and not outside. This would be more prudent. Even when the stock configuration has the fans outside.
Or perhaps its to prevent people from complaining about the lack of space when mounting extra fans or radiator in front. The case design clearly allows that to happen judging by the cutout at the front of the PSU shroud
