Power supply works in any pc except mine
Solved by rodewouw_,
Solution: I have found it
聽
Tye culprit might've been my AC240 wall power splitter to eight different outlets. The poor thing exploded on the inside and stopped working. When testing my main system I worked on it in my room where the outlet died, while testing with the TX750 happened in another room. I do beleive that some damage had been caused to my motherboard, since oc seems less stable (?????)
