Besides that build being hilariously unoptimized, yes it would be.
If you haven't purchased it yet, I'd highly recommend listening to some of the members here who'll undoubtedly try and help you with getting a more functional build.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/661817-how-much-watt-do-i-need/#findComment-8555011
2 minutes ago, !RoW! said:
Is 550 watt psu enouge for This build: http://pcpartpicker.com/list/qwcn6X
The 328W is the max wattage of the syatem, even a decent 350w, or 400w would be good enough ( you might want 400w if you overclock).
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/661817-how-much-watt-do-i-need/#findComment-8555037
Yes, it's enough. Why are you getting Windows 7 when it's $200. Windows 10 is fine and is $100 cheaper. Also, no need to make 2 posts.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
https://linustechtips.com/topic/661817-how-much-watt-do-i-need/#findComment-8555044
It's overkill. A good 450w would already be plenty.
You could get some cheaper like a S12ii 430w: http://pcpartpicker.com/product/4Vzv6h/seasonic-power-supply-s12ii430b
or if you want modularity, a m12ii 520w: http://pcpartpicker.com/product/TgW9TW/seasonic-power-supply-m12ii520bronze
Are you planning a new build? The part choices seem a bit odd.
https://linustechtips.com/topic/661817-how-much-watt-do-i-need/#findComment-8555066
In addition to what the people above have said, please don't spend an entire $200 on Windows. You can get it for cheaper than that.
i7-4790k | MSI Z97 GAMING-5 | Corsair Vengeance 16 GB | Samsung EVO-850 250GB SSD & WD blue 1 TB HDD | EVGA 1070 SC | Red NZXT H440 | Cooler Master G650W
https://linustechtips.com/topic/661817-how-much-watt-do-i-need/#findComment-8555082
Strange choices.
550w will cover it if you're wanting a simple answer.
OP: you say you've already got the parts. If they're unopened and the returns policy on the websites state you can return, have a think. That graphics card had be a bit 'erm..'
EDIT:
Question for OP: Is this a new build or?
https://linustechtips.com/topic/661817-how-much-watt-do-i-need/#findComment-8555124
