Monitor help
Guest riley mclinn
I'm sorry guys but what monitor should I get the price range is 22-26 inches and under 300 doallers US DOAKLERS IM SORRY ALL YALL CANADIAN PEOPLE
CPU: Intel Core i7-6950X 3.0GHz 10-Core Processor  ($1649.99 @ B&H)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($101.99 @ Best Buy)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($11.88 @ OutletPC)
Motherboard: MSI X99A GAMING PRO CARBON ATX LGA2011-3 Motherboard  ($283.98 @ Newegg)
Memory: Corsair Dominator Platinum 16GB (2 x 8GB) DDR4-3000 Memory  ($110.88 @ OutletPC)
Storage: Corsair Force LS 480GB 2.5" Solid State Drive  ($159.99 @ Newegg)
Video Card: EVGA GeForce GTX 1080 8GB FTW Gaming ACX 3.0 Video Card (2-Way SLI)  ($679.99 @ B&H)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($128.49 @ SuperBiiz)
Total: $4078.05
Generated by PCPartPicker 2016-09-16 00:07 EDT-0400
If the pcpartpicker is what you're going with the rig, then I believe you can spend much more than 300 for monitor...
I would suggest 1440p and above for that kind of rig..
Why would you spend 4K on a dual GPU system and ask for a $300 monitor?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
4K for the rig and 300 for the device that actually shows what the aforementioned 4K bring to the table .. seriously? You might as well use your toaster or waffle iron as a monitor ...:ph34r:
With that kind of money go with something that can show porn in UWQHD like this one:  ASUS ROG Swift PG348Q, 34" (90LM02A0-B01370)
Its got G-Sync and pixies and rainbow farting unicorns and whatnot... :-)
