Best £150-£300 overear headphones with bluetooth and ANC
ShadowCaptain
With my move to the iPhone 7, and the fact I am getting tired of my "on ear" sennheiser momentums (awesome headphone btw) I am looking for new headphones
Things to consider:
Over Ear
Closed (but will consider semi/open maybe)
built in mic
Bluetooth
Noise cancelling (active is a bonus)
I have been looking at the QC35s but not a huge bose fan
Things to consider:
Over Ear
built in mic
Bluetooth
https://www.amazon.com/Sony-MDRXB950BT-Extra-Bluetooth-Headphones/dp/B00MCHE38O/ref=sr_1_3?ie=UTF8&qid=1473766564&sr=8-3&keywords=sony+headphones
I love these. good battery life and great soound with terrific noise isolation
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
If you want to hit all those features there's really not much choices that would be a worthwhile upgrade from what you have. Could just sell it and get momentum over ear if you don't like the comfort but like the sound. There's nothing wrong with getting the qc35 either, Bose anc solution is above anyone else if you need it.
58 minutes ago, SlipperyPete said:
Thanks for the recommendation, ill try test some out
Yeah sadly not, I could upgrade to the momentum wireless i guess, although i something sleeker and foldable would be great
yeah the QC35s seem to do everything
3 minutes ago, SSL said:
Bose make the best ANC headphones.
I could live without ANC potentially, if there is some passive noise cancelling etc
My momentum on ears have zero I can hear everything, on a plane at full volume I still barely hear my music properly
ANC would only be used when travelling, so not a daily thing
You're going to need to go for isolating IEMS then, if you want to be sure of blocking airplane noise while maintaining a safe listening volume.
I have IEMs already I want over ear, travel is only a minor factor, I like ANC but mostly just wanting good "portable" over ears that are bluetooth since I will be using the new iPhone 7 plus
  • 1 month later...
@ShadowCaptain sorry to necro your thread but what headphone did you finally get? I'm currently looking at the QC35, Sony MDR100ABN and Sennheiser PXC 550(which is stupidly expensive btw and probably my last option).
Make a new thread for this, and tag OP if you want to see what happened. Or better yet, send him a PM. There is no reason to thread necro...
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
