best £50-£150 headset (built in mic req)
ShadowCaptain
Hey guys, now I know the whole modmic/headphone routine, but my girlfriend doesnt particularly like it (im still working on that)
So I guess, if she MUST have a gaming headset, what would be the best option
I recommended the Hyper X Cloud (especially as they come in pink) but are there any other options? She wants to spend sub £100 but I would happily contribute more, so budget up to £150
I can vouch for the HyperX Cloud. Super comfortable, great noise isolation, good sound stage, and the bass isn't overblown unlike many other options.
Check out my YouTube channel here and don't forget to subscribe :D
Current build: Project Athena
I would say either Razer Krakens or Sannheiser Game Ones
I currently own the Razer Krakens, brilliant sound quality (Very Bassy) and decent quality mic, very high quality construction and customer support is very good, the only major downside is Synapse, the program required to run them, its awful. There are several versionf of the Krakens (One comes in pink) I will link both major versions below as well as the sennheiser, being sennheiser they will sound very good and the mic will be passable but I doubt there will be many problems with them.
Sannheisers
https://www.amazon.co.uk/Sennheiser-GAME-Acoustic-gaming-headset/dp/B00JQDOALC/ref=sr_1_1?ie=UTF8&qid=1473676745&sr=8-1&keywords=sennheiser+game+one
Pink Krakens (Headpone Jack)
https://www.amazon.co.uk/dp/B00KMOLZS0/ref=twister_B00OOT2ZHY?_encoding=UTF8&psc=1
Normal Krakens (USB)
https://www.amazon.co.uk/Razer-Surround-Retractable-Microphone-Lighting/dp/B00MVT7BAA/ref=sr_1_1?s=computers&ie=UTF8&qid=1473677018&sr=1-1&keywords=kraken+7.1
Just now, CrazyfrogXxX said:
SNIP
I wouldnt touch krakens with a barge pole myself, not a fan of razer products or software
Ah yeah the Sennheiser game headsets are a good option
Was looking at the Audio Technica PDG1 also
https://www.amazon.co.uk/Audio-Technica-ATH-PDG1-Premium-Open-Air-Headset/dp/B00OTG9RGE/ref=sr_1_1?ie=UTF8&qid=1473677108&sr=8-1&keywords=audio+technica+game
She wants something interesting looking but, I will try to convince her otherwise
Ah yes, they are a very particular market, the Audio technicas are a good choice, althought I have heard they're quality is either hit or miss, but good luck with whatever you choose.
You should also consider whether or not you want open  headphones. This will be just personal pref and depends on your environment.
Its her quiet bedroom, and she mostly just skypes and games with me and some mates
so not really relevant, she is no audiophile, and is currently using a £7 chinese brand headset
I just want her to have something quality, hate throwing money at bad brands
I am using Steelseries Siberia 650
https://steelseries.com/gaming-headsets/siberia-650
And i never had more comfortable headphones, audio quality is great, you can turn on/off the mic whenever you want just by turning a wheel on the headphones, the volume of the headphones is also adjustable already on them(with a wheel on the other side). The Mic is retractable and has flexible mount so you can change the position of it however you want and it holds there.
The included sound card is a nice feature giving you true Dolby 7.1 surround sound :) Included are the card, 2m extension cable, single jack adapter, jack and headphones adapter.
Dont know what else to say about them, i love them :)
Oh they come in white :P
I was lucky and i got mine for around 90 pounds, now you might be able to get some for 100 pounds totally new no problem i think if you look around.
(f.e. http://www.ebay.co.uk/itm/SteelSeries-Siberia-Elite-Prism-Gaming-Headset-Black-Universal-Gaming-Headset-/201665020306?hash=item2ef42c0192:g:dwQAAOSwyLlXoMZf )
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
I got one of these bundled with my motherboard... https://www.amazon.co.uk/SteelSeries-Siberia-Full-Headset-Microphone/dp/B002Q8IHDQ
It's surprisingly good as a gaming headset. Putting "gaming" in bold because, if you want it for music there are much better options out there. Its strong points are: Crystal clear microphone with great noise cancellation which can retract when not used, and a very comfortable and light design that can sit on your head for hours without hurting. I also fake a 7.1 surround through software sometimes and it works great, but I feel this headset is mainly made for comms rather than anything else, and it's awesome for it. It's open type, which means you can have your games play sound through regular speakers, listen to your voice comms, and still hear your game.
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
6 minutes ago, SaladFingers said:
SNIP
She doenst have speakers, hm virtual surround sound probably isnt much use to her, and she does listen to music on them, hence why I would prefer her to get proper headphones but she doenst wnat the hassle of extra cables or external mics etc!
Could still be an option though
They are "OK" for music. I'm a little biased, having heard expensive speakers and headsets, so I'm just letting you know that high end sound is not their strong point :) Lacking some lows, etc. The surround effect was an example but in theory all headsets should support it. It's a bin-aural gimmick, still uses stereo speakers... But yeah, if she uses them for long sessions then getting something light-fitting can be a game changer too.
If she doesn't want cables, then you could look into wireless sets. Just be advised, sound quality is going to be even worse if you don't go for the more expensive models. There is also this http://www.modmic.com/products/modmic-4-0, which can be paired with any headset that doesn't have a MIC (usually headsets that focus on sound quality) but the whole thing could be out of your budget then.
~ Specs bellow ~
1 minute ago, SaladFingers said:
SNIP
I know all about the mod mic, i said it in my first post, and modmic sent me one to review on my youtube channel :D haha
Its for my girlfriend so its convincing her its what she wants, and she is picky about what she will get
Audio quality is the primary concern as she watches youtube.. listens to music, skypes and games all with the same headset
as I say budget is whatever we decide to spend could get some DT770s and modmic for £150 but she isnt sure that is what she wants
im aware of binarual audio through stereo speakers (hurray for ASMR haha)
I just havnt personally used a lower cost gaming headset for a while so its hard to know about anything semi decent
Oh, I feel like an idiot. I read your OP but somehow I missed the modmic part, sorry.
Imo, if music is a priority then steer clear of gaming headsets. Their priorities are just different, so you wouldn't be getting value for your purchase. They are "OK" to "Pretty good" for music, but not "Great". You could find a much better sounding headset for similar pricing, with less gaming related features. For music playback, I'd also recommend closed type, as background noise sometimes can ruin the experience.
Thing is, usually headsets that include a mic have worse playback than ones that don't have a mic. I think the DT770+modmic would be a pretty nice and high end option if it's in your budget tbh. You could use some velcro straps to pair the modmic's cable with the headset's and achieve the result you are after.
Edit: I didn't know you had a Youtube channel :P Care to share?
~ Specs bellow ~
on my profile :) or search the members review section here
yeah its just they are kinda boring looking and fiddling with the mod mic puts her off (understandable)
Maybe I can pay half and she get get the headset I use, or maybe the sennhesier game headsets since they have pretty nice audio from what I have heard with limited testing
Subbed :P
If you are willing to stretch your budget to around 200 pounds, check out Sennheiser's "gaming" headsets.
~ Specs bellow ~
2 minutes ago, SaladFingers said:
Subbed :P
for that money id make her get another beyerdynamic mmx300
if she wants something cheap then the clouds I guess
That's even more expensive :) But well, cheaper gaming headsets usually lack the sound quality, that's their catch. Pick your poison, heh.
~ Specs bellow ~
its £208 on amazon uk
