Need help finding a good CPU cooler
Go to solution Solved by WoodenMarker,
59 minutes ago, Bananasplit_00 said:
NH d-15 if the case can take it, its the best you are going to get
That can fit with the fans lowered enough.
49 minutes ago, Voltz said:
Yeah, what's good for around $50 ? I heard a lot of good things from CRYORIG H7 but I can't find them for sale anywhere.
The H7 is out of stock in many places.
Good options:
Pure Rock: http://pcpartpicker.com/product/cwPzK8/be-quiet-cpu-cooler-bk009
FUMA: http://pcpartpicker.com/product/dVwqqs/scythe-cpu-cooler-scfm1000
39 minutes ago, Voltz said:
Can the Noctua keep the CPU cool with an overclock?
Sure.
23 minutes ago, reaperfang said:
140mm version of what J400 posted
That doesn't fit in the S340.
So this is my current build plan but I need to find a good air cooler, what do you guys suggest???
http://pcpartpicker.com/list/3K7H2R
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($150.88 @ OutletPC)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($60.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($88.48 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: EVGA GeForce GTX 1070 8GB SC Gaming ACX 3.0 Video Card  ($439.00 @ B&H)
Case: NZXT S340 (Black/Blue) ATX Mid Tower Case  ($75.00)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99)
Case Fan: Corsair Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM  120mm Fans  ($24.99 @ Newegg)
Monitor: Asus VX24AH 24.0" 60Hz Monitor  ($252.99 @ Best Buy)
Total: $1467.80
Generated by PCPartPicker 2016-08-31 16:02 EDT-0400
https://linustechtips.com/topic/652586-need-help-finding-a-good-cpu-cooler/
Builds:
Good options:
Sure.
