JAVA 12 days of Christmas With 2 switches and 2 for loops
Solved by Mr_KoKa,
Ok, so I made a mistake explaining how you can do that in the post before, so I corrected it and now it is ok. You don't use inner loop, just switch, that has cases in reverse order and without any breaks, look at example above, it does it. I cannot edit last post, so there is example without new lines:
switch (i){ case 3: System.out.print('c'); case 2: System.out.print('b'); case 1: System.out.print('a'); }
for i = 1 it will display:
a
for i = 2 it will display:
ba
for i = 3 it will display:
cba
