My Graphics Card has a 8+6 Power Connector. Do I need to plug in 2 seperate Cables ?
21 hours ago, MachmirIndiehos said:i have a corsair rm650x PSU. it comes with with Cables that have 8+8 Pins. Can i use one of those or do i need to plug in to cables into a graphics card that has 8+8(6) power connectors ?
If I read this right, your power supply has one cable that ends with two 8-pin connectors. This is perfectly fine if the wires used in the cable are large enough to handle the current - which you can safely assume they are. (my CX650m is the same way.)
The reason why the graphics card has two separate connectors (1 8-pin, 1 6-pin) is that the thickness and width of the traces available on the graphics card circuit board are not enough to handle the current through only one connector - or more realistically, it's cheaper to use multiple connectors than to increase the thickness and width of the traces (plus other considerations such as the size and placements of filtering components on the power traces).
