I know this topic has got to be beaten to death by now, but I know we have some serious pros in here who can help me get some cables for my new PC. So, I would like to have zero unplugged/extra connections. I am unsure of how many cables I would need and how long to have them made. I am ordering from CableMod.
So is there a typical length that works pretty well? and how can I plug everything in without having extra unplugged connections. My RM100i has so many unplugged connections with the default wiring.
Here is what I am working with that requires power:
Case: Corsair 600c Inverse
Mobo: Asus x99pro
SSD: SAMSUNG 850 Pro
GPU:  Nvidia 1080fe
So I shouldn't have much extra cables, but do people sleeve the cables that connect components to the mother board?
Thanks Linus Fam
https://linustechtips.com/topic/647906-cable-modding-just-the-right-amount/
Could just take a string,  tape it by it's plug and run it the way you want to (dont forget about the real wires bulk when running it) and go to the place where it needs to.
Then take it out, measure it and convert it to MM(millimeters).
I did this with an ITX rig to cut down on cable clutter. I also used some psu cable extensions from a previous build to simulate the bulk of the real cables.
YMMV though.
2 minutes ago, TheOnlyMDK said:
Cool, Ill use the string and measure the wires.
Now what types of power connections do my components need?
1080 needs an 8 pin PCI-E IIRC
motherboard needs a 24-pin ATX
CPU need either a 4 pin or a 8 pin, depends on the motherboard, not sure if it uses the PCI-e cables but its similar to that atleast
SSD needs a single SATA power one
case i dont know but i would guess either SATA or MOLEX
Builds:
