HELP WITH GPU & CPU PLZ
7 minutes ago, LionHeart007 said:
Can't get a quad core, motherboard only handles dual. Also, thanks for the tip. Though, buying new hardware could be a good idea. How? if I slowly buy better hardware, after a while, I'll have almost all I need to make a new PC. Better storage, better GPU, new case, etc. I'm seriously thinking about this. As for the GPU, my current GPU is a Zotac GeForce GT 220 1GB. It only got like 45 Cuda Cores... I'm thinking about a new GPU since it's all I need to run the games I want to play. NFS Hot Pusuit (2010) really doesn't need much to run. At all. So, even if it's somewhat of a waste of money, if I can do it, I'll do it. Buy a new GPU that is... Anyhow, the main question I want answered is; Can I put these two together and get a good performance? Will there be bottleneck, or not?
The most important thing right now is to get a new motherboard and CPU that supports DDR3, and at least a pentium or i3.
Buy the motherboard new, but you should be able to get a good deal on a CPU from craigslist.
If you go for a used GPU you can find something much better than your 220 for less than $50.
