Hey there fellow pc builders,
I was looking to buy myself a new pc, but in the Netherlands this is all very expensive, so I decided not to build one from the ground of. I decided to buy a desktop with a solid i5 processor and a 730 graphics card, looking to replace that graphics card with an rx 480, which my dad could bring from one of his business trips to America for a reasonable price. But, after recieving the pc, it turned out the 730 graphics card didn't have a 6-pin connector on it, it ran solely powered by the motherboard. This is an issue, seeing that I can now now longer swap it out for an rx 480, because I don't have a 6- pin connector to power it. Then a really crazy idea popped into my head, what if I were to buy a cheap 30-ish euro powersupply just to give the rx 480 its power. Do you guys this would work, or have any tips on how to do it otherwise? That would be greatly appreciated.
https://linustechtips.com/topic/647231-power-supply-mod/
Cheap psu = house fire
it may work but it is very much not recommended, the best solution would be to do it properly and get a better psu.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/647231-power-supply-mod/#findComment-8327975
I was thinking about something like a EVGA 430, its EVGA, it shouldnt burn my house down, right?
https://linustechtips.com/topic/647231-power-supply-mod/#findComment-8328014
Those are very low end evga psus, and even though they are evga they are not great at all, I would recommend a seasonic, xfx, or corsair cx with the grey label to run the entire system with, you should only need about a 500w psu depending on the rest of the system.
https://linustechtips.com/topic/647231-power-supply-mod/#findComment-8328043
http://de.pcpartpicker.com/product/zW4NnQ/xfx-power-supply-p1430sxxb9
Simple and cheap, It's quite a bit better in terms of quality of components than the EVGA 80+ white PSU you've listed so...go for that? :D
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/647231-power-supply-mod/#findComment-8328099
34 minutes ago, Nathanpater said:
SNIP
You can get molex to 6 pin!
OR get a not shit PSU
https://linustechtips.com/topic/647231-power-supply-mod/#findComment-8328100
8 minutes ago, SysBus said:
Just get a cheap molex-to-6-Pin adapter
The moment his house catches fire from a blow PSU...
https://linustechtips.com/topic/647231-power-supply-mod/#findComment-8328117
Most OEMs that aren't custom builders have decent PSUs
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/647231-power-supply-mod/#findComment-8328118
1 hour ago, Nathanpater said:
*snip*
forget about the house fire paranoia and get this;
https://www.amazon.com/Electop-Express-Molex-Power-Cable/dp/B01D0XATL8/
Then move-on, it'll be perfectly fine.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/647231-power-supply-mod/#findComment-8328337
