cheap and quiet cooling for fx8350
19_blackie_73
a friend needs a cooler upgrade for his fx8350 (he's using the stock one) and he came up with an arctic-cooling freezer xtreme rev 2.0 for 30€. good investment or are there better solutions? (Germany)
Thanks in advance!
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
1 minute ago, TheRandomness said:
The North Pole.
lemme try this ;)
ok. i talk to him
- Ryzen Build -
2x Dell UP2516D
i5 6600k
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
2 minutes ago, Hero7750 said:
i5 6600k
funny -.- 30€ vs around 500€... find the mistake. He's aware that this chip isn't the best anymore, but just to get this thing more silent does not mean to upgrade the whole pc.
it is not a new build we are planning here.
and tbh: the fx isn't that bad that it needs to be replaced, it is paired with a 680 so ...
- Ryzen Build -
2x Dell UP2516D
I mean the 8320 is a bad cpu
My Main PC:
3 hours ago, Hero7750 said:
i5 6600k
I guess it's technically possible to attach an i5 6600k as a heatsink, although it sounds like an expensive, low performance, and overall risky solution.
A Hyper 212 would certainly be a more conservative approach, though.
im just saying get rid of the 8350
My Main PC:
it's a matter of money I'd say. And a new plattform costs around 500€..... This is a thing that will probably happen at some point of time and not now. We are not in a world were you can pick money from trees like apples and cherrys. and why replace some thing that gets to job done when it is good enough for the one who uses it. No one forces you to use an 8350.
@SpaceGhostC2C @WoodenMarker@AmazingCookie@TheRandomness thanks for helping out, I'll talk to him.
- Ryzen Build -
2x Dell UP2516D
I mean a cpu motherboard an ram upgrade is not going to cost 500€, idk what you are on.
My Main PC:
6600k 250€
somewhat decent Z170 Mobo: 150€
RAM: 50€
Cooler: to get sth appropriate: 50€
I don't know if you can calculate, but this is a sum of around 500€ +/- 50 bucks.
and this is way more than a simple cooler upgrade from stock amd to entry level 30€ cooler to get it more "silent"
- Ryzen Build -
2x Dell UP2516D
2 hours ago, 19_blackie_73 said:
6600k 250€
RAM: 50€
http://uk.pcpartpicker.com/list/cmhChM
you were saying?
My Main PC:
10 minutes ago, Hero7750 said:
http://de.pcpartpicker.com/list/cmhChM
did you read the country? and did you see currency? Even your most basic config is almost 450€. And even parts I'd not take. It's more than ten times you'd have to spend, with not that much I or he would get back.
but i'm outta here. no reason discussing this any longer
- Ryzen Build -
2x Dell UP2516D
i mean you said  500 and that build is  416 so you just proved yourself wrong.
My Main PC:
