Need a little help with rack sizes
1 hour ago, IPickle said:Hi All,
Was thinking about purchasing an 8U wheeled rack enclosure for LAN. Reason being that racks are generally space efficient and i could put some drawers in it for peripherals as well as a PDU and a 4U case for my PC
This was the enclosure i was looking at:
Is there anything i should look out for when i purchase racks / Accessories. Would these enclosures (which are generally used for audio components (I believe?)) work for cases like this?:
I take it i would need rack mounting rails? If I do, what size do I need? 18", 20", 26"?
Are these components compatible?
Sorry about all the questions
Thanks in advance,
-Sam
You will be fine. The case has a depth of 15 inches while the cabinet has a depth of 24 inches. You probably don't need rails, but if the thing is getting bumped a lot, you might want to get some. I'd say get the 20" rails, though I don't really know what the sizes are for.
