Normal Temps?
Solved by AuraDesru,
50 minutes ago, 0ld_Chicken said:I believe that is the "intel enhanced speed step" and your C-states for frequency. I have always had to use adaptive or offset voltage if I wanted my voltage to fluctuate. It can be a bit tricky to keep things stable though when pushing close to the limit.
So I found my answer on another forum, it was due to the fact that I had high performance in power options on at all time. Which led to the CPU always running on 4.3 ghz-4.5ghz all the time on all my cores. I set it to balanced and it dropped to 800mhz on idle. If I load up a program or game, it'll boost it up to 4.5ghz
