Best case ~$80?
Go to solution Solved by xGGAx,
For $89 you can get the Phanteks Enthoo Pro M with full size window. It has everything you need and it is watercooling ready.
There is a cheaper version with a smaller window for $70 bucks
If you can get a Define S for that, do so (it hovers between 65-90 USD). Otherwise I like the S340.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/640318-best-case-~80/#findComment-8255784
are you going to sli? do you want a side window? how many drives are you going to use? There are plenty of cases in that price range but it depends on what you really want / need.
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
https://linustechtips.com/topic/640318-best-case-~80/#findComment-8271257
I have an atx motherboard, I would like a window, and 1 3.5inch drive and one 2.5in ssd. Hope that clarifies
https://linustechtips.com/topic/640318-best-case-~80/#findComment-8272849
https://linustechtips.com/topic/640318-best-case-~80/#findComment-8273145
