EVGA GTX 1070 Issues
OkLoL
Since yesterday my GPU has been giving me low fps. im running all games at 1600x900. before every game gave me 60fps now it gives me 35-46
11 minutes ago, noob at PC said:
have you watched the temps?
no how do you do that
you could use aida 64
Or you can use GPU Z. Either works!
First build every: Intel Core i7 4790K, Asus Z97-A/USB 3.1 motherboard, Kingston HyperX FURY 1866 2x8 16GB Kit, Gigabyte Windforce GTX 970 G1 Gaming, Corsair Obsidian 450D Black ATX Mid Tower, Samsung 850 EVO 250GB & 3TB Toshiba HDD, EVGA SuperNOVA 750W G2, Corsair H100i GTX 240mm, Gigabyte Bluetooth 4.0/Wifi Card, Logitech G700S. Running on Windows 10
Surface Pro 3: i5 4300U with 8GB of ram and 256GB SSD. Running Windows 10 Pro
its at 63c
all my games are running with low fps
Have you tried using DDU to uninstall your driver's then reinstall them from Nvidia?
no but i went on Nvidias website and downloaded a fresh copy and did a clean install
It's best to use DDU to wipe all the drivers off then do a clean install.
Still same issue
Still same issue
it seems like its using cpu's graphic, even thought its plugged into the gpu. and the gpu fans are not spinning.
What game(s) are you playing? What are your computer's specs?
Black ops 3, GTA V, minecraft with shaders
Did you put your DVI/HDMI/Displayport cable into the motherboard or graphics card? It need to be plugged into the graphics card to use its processing power.
P.S. most cards nowadays won't have their fans spin up until they are under load so checking if your fans are spinning doesn't tell you anything.
