Upgrading my rig and need CPU advice.
Solved by Cyracus,
An i5 6500 if you're not looking to OC/budget constrained, paired with a H170 board you can save $50ish depending on mobo quality you desire. A 6600k with a z170 board will squeeze out a bit more with a decent OC
Featured Topics
2
8
2
JFRStudent ·
Posted in Photography and Videography1 -
5
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
