I need help trying to get a new PC put together. I was thinking about having an all-AMD PC, with something like an ASUS mobo, all off of NewEgg. Now that my grandma's PC is done, I realized how slow mine is (and she feels my pain). I let her try it and I got to move in on her new one :D). I'll probably be on a $500 USD budget, and I was thinking if I could build one similar to hers, just with a better processor and graphics card, that would be great. And I'll need a case that can have CABLE MANAGEMENT (BIG mistake on the one I built for her). And of course, a Corsair PSU.
The specs for hers/mine are in my sig, and please help. My old Dell is getting beat to death, and I can barely even play the first CoD on it.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/63085-need-help-with-amd-build-planning/
CPU:  AMD FX-6300 3.5GHz 6-Core Processor  ($109.99 @ Amazon)
Motherboard:  MSI 760GM-P21 (FX) Micro ATX AM3+ Motherboard  ($47.98 @ SuperBiiz)
Video Card:  PowerColor Radeon HD 7950 3GB Video Card  ($209.99 @ Amazon)
Case:  NZXT Source 210 (Black) ATX Mid Tower Case  ($35.94 @ Amazon)
Total: $547.87
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2013-10-06 16:28 EDT-0400)
50 dollars over
Motherboard:  ASRock 880GM-LE FX Micro ATX AM3+ Motherboard  ($54.99 @ Amazon)
Video Card:  HIS Radeon HD 7850 2GB Video Card  ($149.99 @ Amazon)
Case:  Fractal Design Core 3000 ATX Mid Tower Case  ($39.99 @ Microcenter)
Total: $501.93
(Generated by PCPartPicker 2013-10-06 16:31 EDT-0400)
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Are you restricted to Newegg? You'll get less for your buck if you are.
Yeah, because my mom and grandma will only do it with them because they trust them and they don't want to use a whole bunch of sites with their credit cards. (Remember, I am 14, 15 in November).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
I came up with this one, and I'll probably run it in my cheapo $17 USD case until I can afford a really nice one. What do you guys think?
PCPartPicker
EDIT: The reason I probably overshot the PSU by a mile is because I might upgrade it later on down the line.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
PCPartPicker
Just realised that only newegg is a big problem. You could get a 1TB Seagate Barracuda or whatever its called for $6 moar 7200RPM. Get a cheaper DDR3-1600 RAM, I think for $60-70 and downgrade on that Asus motherboard so you can get a 7950 at best, 7870 if things go good.
AMD FX 6300 | ASUS M5A97 R2.0 ATX AM3+ | HITACHI ULTRASTAR 1TB 7200RPM HDD | XFX RADEON HD 7950 3GB | 8GB DDR3-1600 MUSHKIN BLACKLINE | OCZ ZT 550W 80+ BRONZE PSU | ZALMAN Z5 PLUS CASE | LITE-ON iHDS118-04 DVD/CD DRIVE | BENQ GW2255 21.5" MONITOR
http://pcpartpicker.com/p/1LDtH
the reason its a tiny bit more expensive is because its a much better board, you gain front panel usb 3 support which that case has, and plenty or usb rear ports too, you get a heatsinked 6+2 vrm (important for higher power draw cpus and a must-have if overclocking, you get the ability to run crossfire with another 7950 further down the line (we know prices are going to fall on thier arse).
also you have 6x sata3 6gb/s ports which is important if your ever going to buy an ssd. because sata 2 max's out at 360mb/s which ssd's can nowadays exceed.
its asus.....when you get an asus board youll know what i mean.
i would have got an 8320 but they charge 50% more for 33% more cores in the states it seems, here its the other way around (£100 for a 6 core and £120 for an 8?...ill take the 8)
spanking build!
would prefer a higher wattage powersupply but this is fine, on max load youll draw maybe 350watts MAXIMUM
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
spanking build!
Asus is not the way to go for a budget build but it is future proof but there's no point in Crossfire.
PCPartPicker
GET. A. NICE. CASE. With good wire management. AMD does noisy fans, why not upgrade to a 212 EVO + FX 8320.
....seriously?
so your saying if he had a 7950 for $180 its not worth him buying another 1 once the new amd cards come out for another $100 and double his frams/graphics
and asus and msi and gigabyte all have pretty much the same prices for competing products (i know, ive used them all) and asus's driver support from thier website and other software such as fan xpert and biosflashback has always been easier to use and trouble free, thats why people buy them and why for the last year ive put asus board in pretty much all the builds ive done
because he has a budget, lets see what you build?
AMD actually has some of the best stock heatsink fans out.
What about Amazon?
What about Amazon?
I heard they had noisy fans.
It's mostly when people have bad case airflow, have it caked with dust, or don't lower fans speeds.
....seriously?
I meant because if his budget. Also yes, crossfire is good, but not a lot of games support it and if they do it's bad. Crossfire, I would grab it if I could. But you know what Linus says Multiple GPUS < 1 GPU.
You can still get decent cheap cases.
Well OP remember to do what he just said.
It's generally fine for several months without any dust problems. It's just that AMD has been pretty much been using the same mounting system for quite a while and people compare the current heatsinks with the ones in systems that are in 7 years old systems that are caked with dust.
The fan that came with the Sempron is quiet, and really quiet on fan speed 5 out of 9 on my ASRock board.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
What about Amazon?
There's no way that I'll get them to shift from NewEgg. Their credit cards, not mine.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Hmm, I thought most people were fine with Amazon--even more so than Newegg.
Have you tried asking them? It's likely they already use Amazon.
Have another look and see what you think. I refined it a little.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Nope. They want to stick to one thing and one thing only when it comes to this. My mom uses eBay, but I really don't want to do anything with eBay, since you never know if you're going to get screwed or not.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
eBay has pretty decent buyers protection.
You can seriously get better parts even if you just shop at Amazon as well as Newegg. You should go ask them.
Oh well, I didn't really know this. All repots that I had for FX fans were taht they were super noisy.
