thoughts NVDIA Titan X(Pascal)
Solved by Sagar Das,
6 minutes ago, App4that said:Easy, it works. It's actually the reason I'm looking at buying one. If it had HBM2 I'd probably get a 1080. I prefer to know something will work, than gamble. And HBM straight up had issues. Those issues are more than likely cleared up, but 1200us is a lot to spend on maybe.
Good for u i will buy a rx 480, I will say just wait out till vega comes out
