Hi I'm Chikoritâ.
I'm new to the forums.
Id like to know if my current set up will bottleneck my GPU/CPU
I've got the Asus GTX 1070 Founders Edition "brand new" haven't installed it yet but I'd like to know if this will be an issue first.
I've done a little research about this and the results are lets say out of 100% - 50% say yes and 50% say no.
My current set up is :
CPU - i5 4690k (OC to 4.3Ghz) (H110i GTX Crosair 280mm Watercooler)
GPU - GTX 770 OC Edition
RAM - DDR3 16GB Crosair Vengeance Pro Series CL9 XMP Duel Channel
Motherboard - MSI Gaming 5 z97
Monitor - Asus 144Hz VG248QE
OS - Win 10 1511
New Setup: (Only the GPU Changed)
GPU - Asus GTX 1070 Founders Edition
OS - Win 10 1511
Hey thanks for the replies guys, I guess now its time to upgrade. :)
Edited by Chikorita
https://linustechtips.com/topic/623601-bottleneck-help/
As soon I saw the i5-4690K, NO. Unless you're going to play RTS (assuming 1080@144hz) or Crysis 5, you should be fine.
Edit: Playing some of my real-time strategy games on 980 Ti, my CPU only hits about 40-44% save for the Total War franchise where the amount of sprites and calculations is ridiculous.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/623601-bottleneck-help/#findComment-8039112
I would say in 90% (and probably even more ) games and whatever, your i5 isn't going to bottleneck that 1070 :D
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/623601-bottleneck-help/#findComment-8039135
3 minutes ago, Moonzy said:
it depends on the things you're doing
but for most of the games, probably wont be an issue
Right now i'm just planning on playing League of legends, Overwatch. So I should be fine then. Thanks :)
https://linustechtips.com/topic/623601-bottleneck-help/#findComment-8039136
League can run on most iGPU's with no issue and Overwatch is easy on the CPU as well.
https://linustechtips.com/topic/623601-bottleneck-help/#findComment-8039140
Good to hear thanks.
Yep on my current setup those 2 are running fine. I am planning on playing other content as well such as Tomb Raider, Black Ops. Elder Scrolls Online, Blade and Soul
https://linustechtips.com/topic/623601-bottleneck-help/#findComment-8039167
