Troubleshooting problems with TPLink router
Solved by tewynkoop,
2 hours ago, Lloyd said:The router is a TL-WA901ND.
So I looked up the "router" and from what I found its actually AP. So what I think could be causing the problem for you is that the AP has a dynamic ip address and if the ip address on the AP changes from day to day it could be causing all issues on other wireless devices. So you might need to find the actual router and give the AP a static ip and confirm that the settings on the AP are correct.
