Minor Issue after installing RX 480
Matvin
Hey guys.
i recently bought an AMD RX 480, which i installed upon arrival in my PC.
but since i installed i´ve been having a minor issue. When i boot the system the first screen and BIOS screen are in very wierd colors and looks lake something from the 16-bit era.
my guess is that its an old driver somewhere, since ive been to my BIOS to tell it to use the PCI-e port at the startup display.
once it gets the windows 10 login screen, the fan on the GPU does a quick "woosh" and then everything looks fine. so its just the startup that looks wierd.
prior to the graphics card installation i was running the monitor off the onboard graphics of a intel core i5 6600K.
ive also tried uninstalling old drivers using DDU but nothing seems to work.
ideas? :)
where is your monitor plugged to?
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
the monitor is plugged into the GPU
