Advice on how to "decorate" PC
Tweed
I plan to get the NZXT Hue+, and my case is made out of aluminum so I have no idea how it will stay attached if it uses magnets. Anyways, was having trouble deciding whether or not I should get additional LED case fans, in addition to the Hue+. Maybe overkill, idk, im trying to decide whether its too much or if it'll look god damn beautiful. I need advice. Here is my pc case and what other people have done. https://pcpartpicker.com/builds/by_part/vzNypg
The magnets won't stick to the aluminum at all. The best "decorating" you can do is paint in my opinion. Not as scary as it seems, just a little effort and patience.
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
Just get a simple white LED strip. It will give you the best results and it's all you need. They're usually the brightest ones as well.
Mind sending some pics of what it looks like right now? hard to judge what would look cool only with a case to look at...
For example, I have the OG hue in my case, and because of the fact, I laid off putting led fans as well...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
I don't have any pictures nor a device to digitally take pictures lol. But here. How is your PC in the dark?
I dont have access to my desktop right now, and I dont have any pictures of it in the dark, but in certain situations, the internal light "bleeds" out of the front fan areas. This makes it seems like the fans are glowing dimly, which is why I didnt bother with led fans.
Also if you take the route of painting your case, then plastidip is pretty good, as it lets you peel off the paint if you dont like the color/ end up selling the case later.
