Hi, i need some help whit my first pc build. I'm still planing what parts should i use, but for now i am thinking about this parts and want to know if it is going to work properly.
PARTS LIST:
CPU Intel Core i5 4440
Motherboard ASROCK B85 PRO4
RAM Corsair Vengeance Low Profile Black 8GB (2X4) 1600MHz CL9 1,5V
​Graphics card Gigabyte GeForce GTX 780, 3GB DDR5
Storage WD30EZRX
POWER Supply be quiet! STRAIGHT POWER CM BQT E9-CM-680W, 80PLUS Gold
CASE Enermax iVektor White Midl Tower Chasis
THX FOR THE HELP
https://linustechtips.com/topic/61479-hi-i-need-some-help/
I'd get a better cpu if you were going to pair it up with a 780, build seems unbalanced imo, and whats your budget?
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-838126
get a 4670k, z87 mobo and r9-290x
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-838153
That build is awesome, but i would go whit AMD FX-8350, if you are gamer.
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-838191
Dobbel post.
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-838208
wow this community is AWESOME
Indeed :D Hope you have a nice time with us :)
But to the matter: I would advice you to say something more about what this system is to be used for so that we can help you a bit more :)
Things we need to know is for example if you are going to use it as a Gaming system or a editing rig or something else :)
Tor
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-838207
and what MOB you would suggest whit this CPU
It depends on your budged, i would recommend ASUS crosshair V formula-Z (i use it and it is awesome)
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-838216
No problems here, as for ram get the cheapest 8gb modules, remember you will need a decent monitor or you will not be getting the full benefits of upgrading
Listen if you care.
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-838235
Hello
  • Where and when are you shopping, prices differ abit depending on country.
  • How much off a audiophile are you?
  • Where will you place this computer? On a desk, under the desk? This is for me always a thing off importance. If you don't see the case, no need to go all flashy. No need for a window, can get much quiter fans and performance, because you don't care how the inside looks.
  • If you do care about the looks because you will place it on your desk, any color scheme you prefer?
  • What monitor are you using?
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-838382
Hello
well i live in Lithuania and shopping at www.varle.lt. Sound does not matter so much and pc will be on the table. I'll be using Asus VG248QE 24'' LED monitor
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-839642
If you're not in a hurry, wait for the new AMD cards.
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-841537
well i want to buy it this or next month
The new cards should be out by then.
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-842388
i think i have to wait when Linus will review it
That and/or benchmarks.
https://linustechtips.com/topic/61479-hi-i-need-some-help/#findComment-842748
