I have Core i7 5820K slightly OC'ed to 3.8GHZ, and my AIO cooler solution is Corsair Hydro Series H100i GTX
During normal activity (browsing internet, chatting, watching videos) my CPU temp is between 50-55C, and while gaming it reaches 70C ... What bothers me the most that when I check other people builds or reviews for the cooler with the same CPU, it shows way lower temps, 25C when idle and does not exceed 50C while gaming.
I have Enthoo Pro case with 2 Corsair Air Series AF120 Quiet Edition on the front, 1 Corsair Air Series AF140 Quiet Edition on the rear of the case and 2 Corsair Air Series SP120 High Performance Edition instead of the cooler's stock fans. The only fans that intake air to the case are the the ones from the front and also my radiator is installed at the top of the case..
What am I missing here? How can I get better temps ?
Thank you
https://linustechtips.com/topic/614729-normal-temps/
how old is that cooler? Is the pump working well?
Laptop: 2024 16" MacBook Pro M4 Pro, 512GB, 48GB Unified Memory | Phone: iPhone 16 Pro Max 512GB | Wearables: Apple Watch SE | Car: 2025 Honda Accord SE & 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: Sapphire Nitro+ 9070XT | Case: Fractal North | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Seasonic Focus GX-850 | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Noctua NH-U12S | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2024 M4 Mac mini, 256GB SSD, 16GB Unified Memory | Storage: Terramaster D4-320 DAS (12TB Seagate Ironwolf Pro, 12TB Seagate Ironwolf, 6TB WD Blue HDD, 500GB Crucial SSD)
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941449
Seems kinda odd to me. Feel free to attempt to remount the cooler.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941465
2 minutes ago, WaelT said:
Done that at least 5 times.... I had those temps since day 1
can we see a pic of the inside?
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941471
Do temps change when you slow down the fans? Do temps change when you slow down the pump?
Idle temps are pretty high there.
What thermal compound are you using?
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941473
does he have thermal compound? xD
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941477
lol I really started suspecting that :P
I use Arctic Silver 5 High-Density Polysynthetic Silver Thermal Compound
They do not change much .. few degrees
Here ya go
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941489
1 hour ago, WaelT said:
Here ya go
Where are you getting your temperatures from?
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941501
1 minute ago, WaelT said:
Corsair Link. Speed Fan ..
So I see you have a MSI X99A Gaming 7, what does "Command Center" say?
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941523
I just raised the fan's speed to 100%
Either the CPU is faulty or the cooler is faulty.
Do you have a simple air cooler laying around?
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941546
Let's assume the worst case... The CPU is faulty, would I be able to return it or replace it at least?
As long as you haven't OC'ed it, YES!  HAHA...
But if you have OC'ed it Intel might not accept it back.  (I'd also, if I was you, restore it back to default settings NOW to see if it gets any better.  Make sure to check your voltages as well as your frequency)
Also, make sure your memory is operating at the correct speeds, timings, and voltages.
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941562
I was running my CPU at stock speed most of the time.
For my RAM I have Corsair Vengance @3.2GHZ but of course they are not running at full speed (Currently @2.4Ghz) and the only way to get them to that speed is buy OC'ing the CPU right ?
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941567
For my RAM I have Corsair Vengance @3.2GHZ but of course they are not running at full speed and the only way to get them to that speed is buy OC'ing the CPU right ?
What would make you say that?  How about you give me a full list of your hardware components (please include model numbers of everything so I can actually look it up)
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941570
Here you go
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($369.99 @ SuperBiiz)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler  ($107.99 @ Best Buy)
Motherboard: MSI X99A GAMING 7 ATX LGA2011-3 Motherboard  ($238.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($99.99)
Storage: Sandisk Ultra II 480GB 2.5" Solid State Drive  ($108.99)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($117.88 @ OutletPC)
Video Card: MSI GeForce GTX 950 2GB Video Card  ($129.99 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($79.99)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Newegg)
Operating System: Microsoft Windows 10 Pro OEM 64-bit  ($129.95 @ B&H)
Wireless Network Adapter: Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($29.99 @ SuperBiiz)
Monitor: Asus VG248QE 24.0" 144Hz Monitor  ($184.99)
Keyboard: Logitech G710 Plus Wired Gaming Keyboard  ($129.99 @ Logitech)
Headphones: Logitech G35 7.1 Channel  Headset  ($64.99 @ Amazon)
Total: $1993.70
Generated by PCPartPicker 2016-06-22 02:09 EDT-0400
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941578
6 minutes ago, WaelT said:
Here you go
[PCPartPicker part list](http://pcpartpicker.com/list/YrGvKZ) / [Price breakdown by merchant](http://pcpartpicker.com/list/YrGvKZ/by_merchant/)
Type|Item|Price
**CPU** | [Intel Core i7-5820K 3.3GHz 6-Core Processor](http://pcpartpicker.com/product/6tXfrH/intel-cpu-bx80648i75820k) | $369.99 @ SuperBiiz
**CPU Cooler** | [Corsair H100i GTX 70.7 CFM Liquid CPU Cooler](http://pcpartpicker.com/product/MBmxFT/corsair-cpu-cooler-cw9060021ww) | $107.99 @ Best Buy
**Motherboard** | [MSI X99A GAMING 7 ATX LGA2011-3 Motherboard](http://pcpartpicker.com/product/8KZ2FT/msi-motherboard-x99agaming7) | $238.99 @ SuperBiiz
**Memory** | [Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory](http://pcpartpicker.com/product/2skwrH/corsair-memory-cmk16gx4m2b3000c15r) | $99.99
**Storage** | [Sandisk Ultra II 480GB 2.5" Solid State Drive](http://pcpartpicker.com/product/JFJwrH/sandisk-internal-hard-drive-sdssdhii480gg25) | $108.99
**Storage** | [Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/product/XtjG3C/western-digital-internal-hard-drive-wd2003fzex) | $117.88 @ OutletPC
**Video Card** | [MSI GeForce GTX 950 2GB Video Card](http://pcpartpicker.com/product/F2mxFT/msi-video-card-gtx9502gd5ocv1) | $129.99 @ Newegg
**Case** | [Phanteks Enthoo Pro ATX Full Tower Case](http://pcpartpicker.com/product/mn3RsY/phanteks-case-phes614pbk) | $79.99
**Power Supply** | [Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply](http://pcpartpicker.com/product/47mLrH/corsair-power-supply-rm750) | $99.99 @ Newegg
**Operating System** | [Microsoft Windows 10 Pro OEM 64-bit](http://pcpartpicker.com/product/MfH48d/microsoft-os-fqc08930) | $129.95 @ B&H
**Wireless Network Adapter** | [Gigabyte GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter](http://pcpartpicker.com/product/tTdqqs/gigabyte-wireless-network-card-gcwb867di) | $29.99 @ SuperBiiz
**Monitor** | [Asus VG248QE 24.0" 144Hz Monitor](http://pcpartpicker.com/product/rkphP6/asus-monitor-vg248qe) | $184.99
**Keyboard** | [Logitech G710 Plus Wired Gaming Keyboard](http://pcpartpicker.com/product/GBCwrH/logitech-keyboard-920003887) | $129.99 @ Logitech
**Headphones** | [Logitech G35 7.1 Channel  Headset](http://pcpartpicker.com/product/cVMFf7/logitech-headphones-981000116) | $64.99 @ Amazon
 | *Prices include shipping, taxes, rebates, and discounts* |
 | Total (before mail-in rebates) | $2023.70
 | Mail-in rebates | -$30.00
 | **Total** | **$1993.70**
 | Generated by [PCPartPicker](http://pcpartpicker.com) 2016-06-22 02:08 EDT-0400 |
Okay, so with some research, your memory:
http://www.corsair.com/en/vengeance-lpx-16gb-2x8gb-ddr4-dram-3000mhz-c15-memory-kit-black-cmk16gx4m2b3000c15
isn't supported fully on your motherboard:
https://www.msi.com/Motherboard/support/X99A-GAMING-7.html#support-mem
Now, truth is this PROBABLY isn't that big of a deal, I'd suggest that you go into your UEFI and set all the timings, speeds, and voltages manually.
After you do that, go ahead and set the frequency of your CPU back to stock and then make sure your voltages are stock as well.
By doing this we can kinda get a feel of if it is the cooler or the CPU.
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941609
Thank you.. will do that first thinh in the morning and will let you know
https://linustechtips.com/topic/614729-normal-temps/#findComment-7941614
Is it possible to have high temps from RAM?!
https://linustechtips.com/topic/614729-normal-temps/#findComment-7942768
Wow .. I was checking, my current RAM needs 1.5V ....and it is recommended not to go that far... Could that be the case?
First time I know that RAM can generate higher temps ... Is it ok if I lowered the voltage on them manually?
https://linustechtips.com/topic/614729-normal-temps/#findComment-7942804
It will cause the memory controller to work hard, which could cause the CPU to never go into a lower power state.  This is HIGHLY rare and is only seen when using obscure RAM.
So what RAM do you have?  You told me you had modules cmk16gx4m2b3000c15r.  Is that correct or not?
https://linustechtips.com/topic/614729-normal-temps/#findComment-7943706
