Creating rechargeable battery for DIY RC car...
Solved by Hackentosher,
7 hours ago, Anand_Geforce said:I'm in the process of making an RC car, using parts from an obsolete one, like PCB, motors, transmitters, remote, etc. But for the battery, I intend to fix a rechargeable battery that uses a USB connection. How will I accomplish this, and more importantly, what type of battery should I get?
Thanks!
What scale is this? You might want to consider a single cell lipo, those can be charged pretty easily over usb.
