Anyone know of a company that does some serious custom work sleeving wise?
Looking for extensions or a full set for EVGA G2.
With some of this: https://www.amazon.com/TechFlex-MBC0-25CP25-Braided-Copper-Sleeve/dp/B00RO9ZYHY/ref=sr_1_3?ie=UTF8&qid=1466395011&sr=8-3&keywords=copper+braided+sleeve
Want white/black/copper
Thanks!
https://linustechtips.com/topic/613700-cable-sleeving/
Thanks!
CableMod which can be bought at performance-pcs.com. Also BitFenix does some good work and you can find theres on Amazon.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/613700-cable-sleeving/#findComment-7929919
cablemod or icemodz
https://linustechtips.com/topic/613700-cable-sleeving/#findComment-7929920
Did you even read what I wrote? I need custom sleeving done. Like not colours but that link. Predone cablemod won't cut it.
https://linustechtips.com/topic/613700-cable-sleeving/#findComment-7929923
Cablemod has recently opened up their configurator. You can choose custom lengths, colours and everything.
https://store.cablemod.com/configurator/
[Case Mod] Operation: The Division --- > Here
[CUSTOM WATER COOLED TABLE] Project: Ravage ---> Here
-== QUOTE ME IN YOUR REPLY IF YOU WANT ME TO RESPOND ==-
https://linustechtips.com/topic/613700-cable-sleeving/#findComment-7930054
The sleeving in my link is legit braided metal, so it will match my copper piping perfectly, the configurator doesn't have anything of that sort.
https://linustechtips.com/topic/613700-cable-sleeving/#findComment-7930218
Thanks!
considering to add this color for you - for what kind of build do you need it?
https://linustechtips.com/topic/613700-cable-sleeving/#findComment-7930554
Hello Cable Mods. That would be totally awesome. Need a full replacement set for: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817438018&_ga=1.118445641.1536327674.1464653019
I need some way to tie the copper into the build. And that Copper/White/      Light Green and or Black, I think would just make everything complete. Let me know :) @CableMod
https://linustechtips.com/topic/613700-cable-sleeving/#findComment-7932060
got it - will check if our supplier got some copper looking sleeve - can you send me an email to community(at)cablemod.com ?
https://linustechtips.com/topic/613700-cable-sleeving/#findComment-7934828
