replacing cpu fans
MYX
Hello all! I am about to get a new cpu fan and wondering If I need to rebuild my whole pc, I am getting a https://www.amazon.ca/gp/product/B00QMZIJ28/ref=s9_simh_gw_g147_i2_r?pf_rd_m=A3DWYIK6Y9EEQB&pf_rd_s=desktop-2&pf_rd_r=KJRP1EJXR28CQ4C8R9X0&pf_rd_t=36701&pf_rd_p=b420c7ed-0dc7-4f64-beca-b1a9f89477f6&pf_rd_i=desktop which is compatible with my ASUS 68hm plus mobo
I was just wondering If I need to take the whole motherboard out and replace the fan or just simply detaching the old one and attaching the new one.
so basically do I need to take my motherboard out of the case and install brackets, or just use the usual AMD clip
Thanks!
Thanks!
you need to mount the backplate for that cooler so that means pull mobo out replace backplate and remount then reinstall mobo and your done
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
I'm running an Athlon 860k, not going to overclock
3 hours ago, MaxCraft said:
This AMD stock cooler is so whiney DX
my amd stock cooler hit 7,000 RPM while playing bf4
Looks like the  Athlon 860k  is 95 TDP. That cooler is insufficient.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
Black Knight-
Daughter's Rig;
58 minutes ago, asand1 said:
Looks like the  Athlon 860k  is 95 TDP. The second cooler is insufficient. The first is rated for 115W so it should be ok. I personally like my H7 tower cooler.
Black Knight-
Daughter's Rig;
