I just sold my gaming computer yesterday and Im building a new one. I have around $600 to buy a video card, or possible 2 for sli/crossfire but am not sure what to get.
I currently have 3 1080p monitors in surround, but am going to be getting a 4k tv in the future for gaming. I was planning on getting a gtx 1080 but after looking around,
theyre all out of stock and people are saying I would have to wait until august for one.
So for aroung $600, what would be the best graphics card soulution whether it be a gtx 1080, 1070, 970 sli, 980 sli, or a 980ti?
Thanks for any help
https://linustechtips.com/topic/613510-best-gpu-solution-for-600/
Thanks for any help
1080 or 1070
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Thanks for any help
wait for cfx rx 480
Thanks for any help
I mean if you're willing to spend the money and wait then of course the 1080 would be the best option. Of course, you can always wait until AMD release their cards and make your decision then. Although, considering you just sold your PC, I'm assuming you want a quick option. You could perhaps buy a 1070 and sell it later on if needed to get the 1080?
If you are willing to go past 600$, you best bet is the Gtx 1080. If you really can't, I guess a 1070 is your second best bet.
Forget about AMD, they won't offer you anything worth your attention. Not within the next few months anyway.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
Is there any 1070 or 1080 after market cards that havent been released yet so I can snag one on release day?
In theory, they're all released by now, save for the hybrid cards maybe...
Keep at it and you'll eventually find one in stock.
Thanks for any help
If I were you I would wait some time to see what amd provides with the new cards and then decide. If the rx 480 is as good as it supposed to be with 600$ you may be able to do a 3 way crossfire which will have great performance with 3 monitors.
Just don't rush it.
kingpin, but I think it'll be way outside the $600 (:
if you want it right now, today, uno momento - then it'll be 1080, maybe a 980ti SLI (they've been listed as low as $369 recently) if it can fin in the budget
If you're not in the hurry, I'll not even ask you to wait for AMD releases... but for the love of everything that is sacred to PC community... please... I beg you... wait for the 1080ti release, don't buy into this marketing crap
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
Right now there isnt too much for the $600 mark. 1080S are at least 650, 1070s are 450, and multiple card setups are still not suggested unless you have no other choice. The 1080ti will probably push the 1080s to the 600 mark, and Vega will likely have a card for around that but both of those are months off.
So. Either bump up to a 1080, save money with a 1070, or wait for the later releases.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
