Hi!
I plan on building my very first PC; I used to buy those pre-built computers, but my guess it that a custom built pc is much more reliable and upgradable thus lasting longer.
http://pcpartpicker.com/list/fqz4D8
You can see all my parts above;
I plan running windows 10 64bit on it; and use it for gaming as well as video recording and editing.
You'll see I've put a pretty heavy power supply on it (750watt, according to pcpartpicker the draw would only be 300 watt), that's because I'll probably upgrade to 2 more powerful graphics cards (==> SLI bridge); but for now the GTX 960 4gb should be enough I guess (what do you think?); should I go for a lower powwer supply?
I also have a whole bunch of hard drives laying home, anything will work for that I'll use an SSD for booting (and slap a 3,5" HDD in there too for storage)
I fix my budget to 1200$; I do want DDR4 ram, and I won't spend over 300$ for a graphics card at the moment.
Do you guys have any tips or modifications to suggest?
Thanks for your time!
Ben
Edit
1. Budget & Location
Below 1200$
2. Aim
Gaming, programming, video-editing
3. Monitors
An ultra wide monitor.
4. Peripherals
uhm? keyboard and mouse
5. Why are you upgrading?
Currently on a laptop; my tower is a granny PC.
Edit number 2
I changed it a bit, it now looks like that
http://pcpartpicker.com/list/wxX8d6
https://linustechtips.com/topic/613484-first-pc-build-need-advice/
Things I would change:
#1 Iwould get a cooler master hyper 212 evo for your CPU cooler instead.
#2 That motherboard is awfully expensive for your CPU.... Since you're doing video editing you could consider downgrading to a mobo more around 120 dollars and getting a 6700k. Of course, you could just downgrade the mobo and leave the CPU :)
#3 AMDs rx 480 is launching on June 29th, will cost only 200 dollars, and should perform around an r9 390x-GTX 980. You should get that instead of a 960 for sure.
#4 That psu is overpriced. I'd recommend an evga g2 650 or 750 watt psu instead.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
I'd search for a less expensive motherboard and power supply for sure. Those are way too expensive for what you're actually getting out of it.
GPU prices are dropping really hard so you can get one for $300 that will be better than a 960. For gaming I'd suggest a RX 480 or waiting for other cards to drop in price.
2 minutes ago, Beben107700 said:
I don't think I'll overclock the CPU; If I do I plan on buying http://www.corsair.com/en/hydro-series-h110i-280mm-extreme-performance-liquid-cpu-cooler
Not sure yet though
and why is the GTX960 a no-go?
If you don't plan on overclocking, get a normal i5-6600. GTX 960 is a no go since the RX 480 will be much better for only $200.
Definitely go for a i7 if the budget allows it. It'll help a lot when it comes to video editing.
Thanks DocSwag!
#1 I'll follow your advice on the cooling, 5$ more is not a problem
#2 For the motherboard, I consider keeping for a bunch of years; but I guess you're right. Also would an i7 be overpay?
#3 Alright I didn't know that! I'll definetely have a look at that
#4 Wow that's a lot cheaper !
As said above i would cheap out a bit on the mobo, and put it the money somewhere else. GTX 960 no go, r9 380 would be better and even so new gpus that are quite more powerful are coming out in the same price range. PSU if you are thinking of SLI or Crossfire go for 750 w but again i would prefer a better single gpu over a sli or cfire. PSU rmx 750w would be cheaper and a good one too so you can cut some money of there too. CPU cooler for a budget system an coolermaster 212 evo would be great.
8 minutes ago, Beben107700 said:
Thanks DocSwag!
i7 only for gaming is not value for money. I would do it cause i like the extra power but if you are on a tight budget i would not consider it as an option
26 minutes ago, Beben107700 said:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($324.99 @ Newegg)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.89 @ OutletPC)
Motherboard: Gigabyte GA-Z170X-GAMING 6 ATX LGA1151 Motherboard  ($137.49 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory  ($57.99 @ Newegg)
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: Corsair RMx 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($70.00 @ Newegg)
Monitor: LG 25UM56-P 25.0" 60Hz Monitor  ($150.98 @ Newegg)
Keyboard: Cooler Master CM Storm QuickFire XT Wired Slim Keyboard  ($85.63 @ Amazon)
Mouse: Logitech G402 Wired Optical Mouse  ($44.39 @ Amazon)
Other: RX 480 ($200.00)
Total: $1156.35
Generated by PCPartPicker 2016-06-19 13:26 EDT-0400
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler  ($72.25 @ OutletPC)
Motherboard: MSI Z170A SLI ATX LGA1151 Motherboard  ($124.99 @ SuperBiiz)
Case: Corsair 450D ATX Mid Tower Case  ($99.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($84.99 @ NCIX US)
Other: RX480 8GB ($230.00)
Total: $995.20
Generated by PCPartPicker 2016-06-19 13:32 EDT-0400
If your $1200 budget doesn't include storage or Peripherals, you could go with a 1070 or dual RX480 you know :P (by the way, how much do you edit and what ever? If it's massively more than gaming and whatever, you could always jump onto the x99 platform :D).
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
If you don't plan on overclocking, this is the build you should get:
http://pcpartpicker.com/list/TFRcf8
I changed out your PSU to something almost equivalent, but a fair bit cheaper. the HXi 750 MIGHT be slightly better on paper, but in your use-case, you wouldn't notice any difference at all. (You can still go with HX750i, but the Supernova 750 P2 was much cheaper at the time of this post). I got you an i7-6700, and H170 board. You can of course still go 6700k and a Z170 if you want, but it would cost a few extra bucks. and a single RX480 8GB version to round it out. You can Crossfire 2 of those later on if you wish and it would be a system to be reckoned with (without any benchmarks to see exactly how good it will or will not be, I would wager somewhere between 1070 and 1080 performance)
On 6/20/2016 at 2:10 AM, Beben107700 said:
Also, if I do plan on overclocking, would a liquid cooler really be necessary?
Not necessarily unless you want to run even lower temps or even higher overclocks than that cooler can provide. I have that same cooler on my i5-3570k and I've overclocked it from 3.4 to 4.4 without hitting 70 degrees. Had to dial it back because of some crashing to 4.2 though. For the money you'll spend on the cooler it will give you a nice area to play around in for overclocking. If you decide you want to get really serious with it, then pick up a liquid cooler. For beginner overclockers it'll do a very good job.
