Won't boot - No CPU fan
6 minutes ago, Enderman said:there should be a setting in your UEFI to change "minimum rpm" to "ignore" so that it doesnt give you any warnings when the fan is at 0rpm
10 minutes ago, bgibbz said:Yes. I haven't used that bios, but look in advance settings and find he setting that allows it to boot without a CPU fan. If you look back at linuses 7 gamers 1 CPU video, he experienced the same problem on an Asus motherboard so you might be able to catch where the setting is located in bios.
2 minutes ago, ★ Coups ★ said:I had gone into advanced and to monitoring and put the monitoring to ignore. Is that the trick? If not, how do I actually get to UEFI?
Alright. I turned off monitoring and it's booting into Windows now. Is there anything I should look out for with this kind of setup?
Thanks guys
