Hello. In Sweden (where I liv) a GTX 1070 costs 749 dollars or 5999kr. Kr is the Swedish coin. One dollar is 8 swedish kr. I really want to get a 1070 but the prices are to damn high. I wondered if I'm not just better of getting a used 980 or 980ti. You can get a 980 for around 375 dollars or 3000kr  used in Sweden. If your lucky you can get a 980 for around 450 dollars in Sweden. What should I do. I also have the opertunity to buy 2x GTX 780 for only 250 dollars. Is that worth it or is the cards so old that it is just going to be to porly optimised with drivers? Help me pls. Thanks
https://linustechtips.com/topic/612674-help-me-decide-witch-graphics-card/
first off go for 970 or 980 ti
if you cant afford 980 ti then go with 970 as you can then save for a next upgrade.
980 logically is not better than the 970 enough to warrant the price difference.
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
Buying a NVidia card before the XX80ti launches is paying an early adopter tax because the TI launch always drops the prices of the other cards. Buying a founders edition card is paying early adopters tax on top of early adopters tax.
Main Rig: http://linustechtips.com/main/topic/58641-the-i7-950s-gots-to-go-updated-104/ | CPU: Intel i7-4930K | GPU: 2x EVGA Geforce GTX Titan SC SLI| MB: EVGA X79 Dark | RAM: 16GB HyperX Beast 2400mhz | SSD: Samsung 840 Pro 256gb | HDD: 2x Western Digital Raptors 74gb | EX-H34B Hot Swap Rack | Case: Lian Li PC-D600 | Cooling: H100i | Power Supply: Corsair HX1050 |
Pfsense Build (Repurposed for plex) https://linustechtips.com/main/topic/715459-pfsense-build/
Ok ty I might just do that. The non reference edition doesn't exist in Sweden
16 minutes ago, Alvin The bad keyboard said:
The 980ti is going for around 475 dollars
then get the 980Ti
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
