Best 160mm tall CPU cooler
Infin8
Looking for the best (highest tdp) Heartsink that is not higher than 160mm.
It should also have good RAM clearance and shouldn't overhang the 1st pcie slot.
My Mainboard is the MSI Z170I, my CPU the 6600K and my case the Fractal Design Core 500.
I'd probably get the NH-U12S. But I'm kind of bias towards Noctua products, love their stuff.
not sure exactly what you're looking for for ram clearance, but the nh-d15 comes in at 160mm, can end up being taller depending on fan placement, but the cooler itself is 160mm and fans can be placed to not exceed that
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
The NH-C14S would definitely fit, but I suspect that you are overthinking the compatibility issues.
